tremec t-5 problems.. help please
  • Thread starter Thread starter torch93
  • Start date Start date Aug 27, 2010
torch93
143
bakersfield c.a
Aug 27, 2010
  • Aug 27, 2010
hey guys i got a tremec t5z? something like that but wen i installed it and took it for a test run i found that my second pops out wen i try to shift? as soon as i let go of the clutch it pops out i try to hold it in but i let go of the clutch and it grinds really bad.. but heres the thing wen i down shift from 3rd to 2nd is goes in find (most of the times) and if im at a dead stop and take off in 2nd gear it wil work fine... what could this be? syncro? spider gear??? or my 2nd gear is no good? ... is it hard to fix that myself? or do i go to my local shop?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 28, 2010
  • Aug 28, 2010
Two possibilities:
1.) Bent or damaged shifter mechanism
2.) Bad 2nd gear syncro.
Either one will require the removal and disassembly of the transmission.
I don't know how you feel about the DYI thing when it comes to gears, some people don't like the idea of working on transmissions. If the DYI transmission fix idea isn't something that you would rather leave to someone else, here are some resources:
See TTC: Product Literature to download a FREE service manual for T5 or Tremec 3550/TKO
You will need the Adobe Acrobat viewer which is also a free download – Adobe - Adobe Reader download - All versions
See Hanlon Motorsports - T5 and Tremec parts, sales and service or Welcome to D&D Performance - The 5 & 6 Speed Experts! for parts
A T5 rebuild kit with syncros, bearings and other small parts costs about $160-$200. It does not include any gears or shafts.
Hanlon Motorsports - T5 and Tremec parts, sales and service also has a video on how to rebuild your T5 or Tremec. It costs about $20, and is worth every penny of it.
I did a Tremec 3550 rebuild, and it wasn't that difficult. The video was an immense help, and I would recommend viewing it. At $20, it will give you an opportunity to look and decide for yourself if you think that it is something you want to try to do.
Mustang5L5
Mod Dude
Feb 18, 2001
43,368
18,114
224
Massachusetts
Aug 28, 2010
  • Aug 28, 2010
Make sure your shifter stop is not set too close to the shifter preventing it from fully extending into hear
V
v8only
2,378
22
49
Aug 28, 2010
  • Aug 28, 2010
I agree, check the shifter first, back out the shift stops, the drive without both shift boots on, as it could be hanging on a boot.
Other than that, it's the syncro, slider or gear itself, or bad shift fork tabs
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
Drivetrain Decode this Tremec tag?
  • Scott_S
  • Jul 25, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
