Tremec TR-3550 install
  • Thread starter Thread starter jbcottrell
  • Start date Start date Nov 8, 2004
J
jbcottrell
  • Nov 8, 2004
How difficult is it to install a TR-3550 in a 90 5.0? What parts do you need besides the trans. itself?
V
v8only
2,378
22
49
Nov 8, 2004
  • Nov 8, 2004
just the specific tremec bell housing and an adjustable trans x member. Make your oem one adjustable by grinding the tac welds off the tubes.
4dStang
Banned
Oct 23, 2002
718
Near St Louis, Missouri
Nov 8, 2004
  • Nov 8, 2004
A 1995 Cobra R bell housing is the proper bell for the TKO 3550. As far as I know, the 3550 does NOT come with a shifter as the TKO500/600 do, so you'll need a shifter. Do the grind on the mount and you will have to measure, after the install to see if your drive shaft length fits correctly. If not, have the tube replaced at a DS shop (cheap) and that should be about it for Tremec specific parts.
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Nov 8, 2004
  • Nov 8, 2004
Bellhousing has been addressed.
The 3550 comes with a shifter, just not a handle. You can reuse your T5 handle.
Crossmember will fit fine with the gind/re-weld method or get an adjustable or get an AOD one.
Driveshaft should be fine -- it will fit like in an AOD.
Kid wita 5oh
I'm definitely not in the original hole
1,409
150
93
Saugus, MA
Nov 8, 2004
  • Nov 8, 2004
a standard t5 bell housing is the exact same thing as the "tremec" bellhousing..dont spend the extra $$
N
nickg42oz
358
New Orleans, LA
Nov 8, 2004
  • Nov 8, 2004
Its not the same bellhousing, well sort of. The size and shape are the same but the bolt holes are in diffrent places.
V
v8only
2,378
22
49
Nov 8, 2004
  • Nov 8, 2004
you can also find a four eyed guy with an old srod bell, those will work too.
Stang8URMPRT
1,100
Daytona Beach, FL
Nov 8, 2004
  • Nov 8, 2004
Yep, and 4 speed to 302 bellhousing will work. Also, you can just slot the tranny mount to crossmember bolt holes a little farther back instead of breaking the tack welds. This is what I did to get mine to work. Other then that, it's straight forward.
Nick
Kid wita 5oh
1,409
150
93
Saugus, MA
Nov 17, 2004
  • Nov 17, 2004
nope they are identical i mounted the tremec up in there with both of, and on the "tremec" bell housing you can see where the ford part number was removed
SlowGT
826
Columbia Co, PA
Nov 17, 2004
#10
  • Nov 17, 2004
  • #10
They are not identical. The bell to block pattern is the same and the depth is the same, but a 3550/TKO bolt pattern is not the same as a T5. The older 4spd bells match the 3550. Tremec even tells you the part # for putting a one in place of a T5 (D9ZC-6392-C). See page 6 in the Tremec service manual. If they were the same, a 3550 would bolt up to a Lakewood 15203 (T5) but they don't. They match to a 15202
D
96 get convertible-sell or part out?
  • DTCstang
  • May 17, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? May 18, 2026
nickyb
Engine 86-93 V8 Distributor Collar Differences
  • AeroCoupe
  • Feb 15, 2025
Fox 5.0 Mustang Tech Mar 9, 2025
AeroCoupe
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
Manual Transmission Rebuild Resource
  • hoopty5.0
  • Apr 3, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 3, 2025
AeroCoupe
