It’s been awhile since I’ve purchased it, which GM Synchromesh do they recommend? #104006 ACDelco Synchromesh Transmission Fluid or #104014 ACDelco Synchromesh Transmission Fluid Friction Modified? Or a different one? Thanks
This is the best transmission fluid you can put in your Tremec transmission. It also makes T-5 and T-45 transmissions shift more smoothly. NOTE: Supersession to new AC Delco 10-4006 (88900333).
www.steeda.com
In the description it says "NOTE: Supersession to new AC Delco 10-4006 (88900333)" which is one of the fluids you listed
