tri-ax, low or high?
03redfiregt
290
Dracut Ma
tir ax, low or high
I have;nt installed my tri ax yet since the car is in hibernation in the garage but i don't know if i should mount the handle in the lower or higher position? I know the higher position is probably the most comfortable wich is why i'm leaning that way but i;m sure alot of people put them in the low position. What are the pros and cons? :shrug:
I've got mine set on low, I figure the lower the less distance my shifter has to travel for each gear. Come to think of it, I forgot why I chose to go that way. It takes time getting used to from the stock height of the shifter.
Low was too low for me. I personally like it in the upper of the 2 postions. You still have a very positive feel when shifting, but you don't have to move your seat up to adjust for the lower setting.
I tried both..
first low - loved it..
then switched to high - the throw got longer (longer than the stocker) It shifts easier(doesn't require as much effort) than the low setting but I don't like a long throw..
So I switched back to low and never went back to high.
Bottom line is to try them both and see which you like best. :)
Lowest, only way to go. Although, I shift just as fast with the short throw as I did with the stock shifter :( I don't think there's any way for me to shift faster unless I get an adjustable clutch cable or something of that nature. 0_o
I tried both. Lowest first, then highest. Liked the highest much better. It is easier to reach, and my tranny seems to shift easier at the highest setting. The 1-2 shift in the lowest setting is more difficult than the highest. Just my opinion...
Bill
