hi, i have a 95 cobra 23,000 miles and stock except for 3.73's, offroad h, cat back, and the tri-ax. my problem is that i have occassional 3rd gear grind when i shift into gear but even before i take my foot off of the clutch. i adjusted the stops to make sure it is going all the way into gear and it definitely is. i don't think the stock shifter was doing this but i only had the car for a very short time before i did the swap so i'm not sure. any ideas what could be causing this? i guess the next move is to put the stock shifter back on and see what happens.
