89 hatchback, 4.30 gears, 5 speed, 302 with fresh bottom end, trick flow 190 heads, trick flow upper/lower intake. what off the shelf cam to use? was thinking about the stage 3 tfs cam but i'm interested in other options. car will not be run on the street, looking to get deep in the 11's on motor and in the 10's with a shot of nitrous. not looking for a nitrous cam, want it to run strongest on motor alone.
.... 190's are not "a bit much for a 302"....... they simply do not require such an aggressive camshaft on the intake to perform more efficiently. Or are 260cc heads a bit much for OEM 376 CI engines used in '07+ trucks and SUV's by GM?
