- Aug 16, 2007
- 79
- 0
- 0
I am looking into the trickflow street heat combo aluminum heads, cam intake, etc.any comments on these kits what power increase can I expect?
Sicarius - I imagine some of that extra 30hp is from added compression or other inconsistencies...
Sometimes loose (older engines) is actually better![]()
I highly recommend the kit! I'm running the TrackHeat with the Stage 2 Cam and I'm putting down 310 to the wheels. I would strongly recommend going with atleast 30lb injectors. With my combo I'm running out of fuel at high rpm's. Like already stated make sure you get new lifters since the kit doesn't come with 'em. If you're gonna do it, and money permits, get a bigger t-body and MAF.
Don't believe the hype either... you will most likely need a tune when done. I know I did.
