trick flow heads which ones to buy so many choices
  • Thread starter Thread starter 88GTBlack
  • Start date Start date May 11, 2010
88GTBlack
14
  • May 11, 2010
88 GT MAF conversion car w 3.73s otherwise stock.
For its waiting HCI upgrade, I have track heat upper and lower intakes, 75mm throttle body #24 injectors.
I have everything but the cam, heads, and timing chain.
Stock bottom end car, what heads will work best with my setup without PTV issues. I plan on making most possible power w/ stock bottom end N/A no boost no juice.
5.0L/302, FORD, Trick Flow Specialties - trickflow.com
I was considering the 190cc Track heat heads? what kind of cam?
Tanus
847
A to the Z
May 11, 2010
  • May 11, 2010
Id go with trackheats 190 and stage 2 cam, probably have PTV issues though
88GTBlack
14
  • May 12, 2010
what are my options if i run into ptv issues if i do ill be maxxing out budget and end up pulling out the slugs if i could somehow steer clear of ptv issues that would be great
steelie4u
78
  • May 12, 2010
i went with AFR 165 heads and trickflow stage 1 cam and streetheat intake am in the process of installing these but from what i heard it should be a very good combo, also i shouldnt have any PTV problems, from what i read you will have to nothch the piston heads to get the clearence, only way to know is check PTV cause its different on each car
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
94 GT HCI: Won't find /hold idle when Warm to Temp
  • 1994FiveO
  • Jun 10, 2023
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Jun 14, 2023
1994FiveO
