Trick Flow intake question
LaserSVT
3,542
233
Does the Trick Flow Track Heat intake require a custome A/C hose to clear it? Was looking at a Fox and the guy said he removed the hoses cause it didnt clear and their was a special hose that had to be ordered. I didnt know the Track Heat was so much larger that the regular Trick plenum that the stock hose wouldnt fit :shrug:
I don't have a custom hose with my Trackheat intake. When it was installed without the 1" spacer the A/C hose went over the intake. With the 1" spacer the hose goes under the intake plenum on the drivers side.
