trick flow kit
  • Thread starter Thread starter evilwater
  • Start date Start date May 6, 2006
evilwater
70
windom MN
May 6, 2006
  • May 6, 2006
I just bought the trick flow kit with the twisted wedge heads for my 88 mustang gt and was woulndering if anyone else has the same setup and can tell me what they get for times??? and was woundering what to do after i have this kit put on to get more power here is what i already have done
mac equal length shortys
mass air systems 75mm billit mass air with the new program
24lb fuel injectors
kirban fuel pressure regulator
full exhaust redone with no cats and turbo mufflers
UD pulleys
im also going to rip apart my short block and do all the barings and rings.
evilwater
70
windom MN
May 7, 2006
  • May 7, 2006
any ideas?
J
jjd975
4,236
louisville,kentucky
May 7, 2006
  • May 7, 2006
No reason the car cant make 300 to the wheels. Based on how the car is set up (gears,suspension and driven) it could run high 11s to low 13s.
M
mackey
1,284
Beverly, Massachusetts
May 7, 2006
  • May 7, 2006
gears
evilwater
70
windom MN
May 7, 2006
  • May 7, 2006
o thats another thing i forgot to put in a have 3.55 gears
evilwater
70
windom MN
May 8, 2006
  • May 8, 2006
anyone else have any thoughts???
F
frcefedlx
184
  • May 8, 2006
Bigger throttle body if your still using stock one. I would think 65 or 70mm would be fine. I would change the lifters while you got it apart also.
vikingpower
656
CWU Ellensburg, WA
May 8, 2006
  • May 8, 2006
I'd recommend pulling the heads apart and spending a few hours polishing the ports with a cartridge roll kit and port matching the intake. I assume you have a bigger T.B., I use a 75mm. Also be ready for the Surge Dragon... but the power is nice, very nice; dont be afraid if you tag the rev limiter a few times
evilwater
70
windom MN
May 8, 2006
  • May 8, 2006
ok thanks everyone but thats the wierd thing i dont think i have a rev limiter i can wind it up sky high and it will just keep on going. any one know anything about this??? o ya i also have a 70mm tb by bbk.
wild86stang
115
Milan, OH
May 8, 2006
#10
  • May 8, 2006
  • #10
Should be at 6250 if I'm not mistaken, I wouldn't purposely try to rev above that unless you've built your engine for it. The stock limiter cuts out fuel and engines don't tend to like that. I pieced my kit together individually and got Track Heat heads and 1.7 rockers. It sounds great but unfortunately I don't have numbers yet. 300 to the wheels is what I generally hear. I'll make a thread when it's completely finished and I have numbers and pics (shouldn't be too long).
Trick Flow Series R to Box R Upper Intake Road Block
  • Habu135
  • Mar 31, 2026
  • 2 3 4
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
Habu135
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Engine Popping noise in the intake. Frustrated still.
  • esteban31065
  • Apr 6, 2025
Fox 5.0 Mustang Tech May 23, 2025
gkomo
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
