trick flow kit
evilwater
70
windom MN
I just bought the trick flow kit with the twisted wedge heads for my 88 mustang gt and was woulndering if anyone else has the same setup and can tell me what they get for times??? and was woundering what to do after i have this kit put on to get more power here is what i already have done
mac equal length shortys
mass air systems 75mm billit mass air with the new program
24lb fuel injectors
kirban fuel pressure regulator
full exhaust redone with no cats and turbo mufflers
UD pulleys
im also going to rip apart my short block and do all the barings and rings.
I'd recommend pulling the heads apart and spending a few hours polishing the ports with a cartridge roll kit and port matching the intake. I assume you have a bigger T.B., I use a 75mm. Also be ready for the Surge Dragon... but the power is nice, very nice; dont be afraid if you tag the rev limiter a few times
ok thanks everyone but thats the wierd thing i dont think i have a rev limiter i can wind it up sky high and it will just keep on going. any one know anything about this??? o ya i also have a 70mm tb by bbk.
Should be at 6250 if I'm not mistaken, I wouldn't purposely try to rev above that unless you've built your engine for it. The stock limiter cuts out fuel and engines don't tend to like that. I pieced my kit together individually and got Track Heat heads and 1.7 rockers. It sounds great but unfortunately I don't have numbers yet. 300 to the wheels is what I generally hear. I'll make a thread when it's completely finished and I have numbers and pics (shouldn't be too long).
