My friend said I can have his stage to cam if I want it but I want to make sure it will clear first.I ahve a stock lower end with afr 165's and 1.7 rockers.Any help would be great.
you might have to change to the 1.6 rockers but it would be worth it. just check the piston to valve clearances if you wanna try the 1.7's. or you could call trick flow and ask them. i have the stage 3 and trick flow recommends 1.6 rockers with it.
