I'm looking into purchasing the Trick Flow Track Heat kit from summit. It comes with twisted wedge heads, upper and lower intakes, rods, rockers, timing chain and gears, cam, etc. Any comments about this or what else i might need on my engine?
You are going to need to buy Trickflow's Oil filler kit or else you have no way to get oil into your engine without taking off the valve covers. I have the same kit except street heat. I should have spent the extra 50 for the track heat manifold.
summits part numbers are tfs-k514-360-350 for the track heat kit. it says it put the engine up to 360hp 350Lb/ft torque. seems like good power and solid products to build on
