310stanger
- Aug 15, 2006
- 170
- 1
- 0
when u set your valves make sure the lifters are bled down and its also best to do them when both valves are closed. once again, this kit is intended to be used with MAF and 24 inj and at least a 155 pump. between the cam freaking out the speed density, and the engine prolly is dying for more fuel. you can keep tip toeing around this all you want. i promise you this is where your problems are. call trickflow.
