  • SN95 4.6L Mustang Tech
Trouble Code Help
  • Thread starter Thread starter BlackenedSVT
  • Start date Start date Aug 30, 2006
BlackenedSVT
1,841
New Jersey
Aug 30, 2006
  • Aug 30, 2006
After i had my gears installed i've been getting this ABS light on the dash. No idea why, so my X-cal2 just got here and its showing a P1233 FPDM Code. I'd imagine its ABS related of course, but not sure what. An old brick snap-on scanner said there was a problem with my RR ABS sensor "receiving no input". But its plugged in.
Maybe the sensor is dirty? Can someone give me some more info on the code? I dont see how removing the ABS sensor and plugging it back in for hte gear install would KILL the sensor. So im a little confused
M
MidnightBlk98GT
45
FL
Aug 30, 2006
  • Aug 30, 2006
I hit a couple of websites and I keep getting this response
P1233 Fuel Pump Driver Module off-line
so I don't know if you have had anyone poking around in there but I'd take it back and give them a tongue lashing. Have no clue as to why the ABS light is on.
BlackenedSVT
1,841
New Jersey
Aug 30, 2006
  • Aug 30, 2006
Yeah the ABS light is on and its giving me that code. Something doens't seem right.... This all happened after a Gear install...
Along with the ABS light, its also disableing my traction control.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Aug 30, 2006
  • Aug 30, 2006
The X-cal2 only scans the PCM, it will not scan the ABS module or any of the other modules in the car.
If you are getting a RR abs sensor code then most likely the sensor is bad, this is sort of common on all fords. If you want to be sure you can check all the wirring up to the sensor and see if it's fine.
BlackenedSVT
1,841
New Jersey
Aug 31, 2006
  • Aug 31, 2006
So if its common, whats the common problem? Dirty sensor? Or is it failed and i need a new one?
BlackenedSVT
1,841
New Jersey
Sep 16, 2006
  • Sep 16, 2006
Hooked my car up to a snap-on scanner again. Throwing code:
C1235 "RR Wheel Speed SNSR Input Missing
Mike97gt
it doe snot
10,633
Sep 16, 2006
  • Sep 16, 2006
it's most likely the sensor. you may have damaged it during the gear install.
BlackenedSVT
1,841
New Jersey
Sep 16, 2006
  • Sep 16, 2006
Yeah i priced one out from a parts store i get discounts at. They can get me the Motorcraft sensor for $47. So i may just buy one and install it later in the week.
I'm wondering if ABS sensors is a "replace the broken one" fix, or is it one of those "replace both rear sensor" fixes??
Mike97gt
it doe snot
10,633
Sep 16, 2006
  • Sep 16, 2006
just replace the broken one.
Engine Code 41 again
  • Creomod
  • Jul 7, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
Mcmahst
  • Gulftown980x
  • Jul 29, 2026
squeak93
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
R
93 LX 2.3 Trouble codes 53, 85, 21 help
  • Rickshaw302
  • Apr 15, 2025
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Apr 18, 2025
AeroCoupe
N
Complex changes need help
  • nomoremasks
  • Sep 15, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 15, 2025
nomoremasks
N
