Trouble Finding Parts
  • Thread starter Thread starter Woodtick_02
  • Start date Start date Dec 12, 2014
W
Woodtick_02
  • Dec 12, 2014
Im in the process of changing over the front suspension on my 83 fox and have ran in to a snag. I changed to a tubed K member and arms and when I went to put my coil overs on the sleeve would not fit over my struts. I did knock off the ring at the top of the strut but it still will not fit. The strut housing is 2.125 diameter and that is the same size as the id of the coil over strut sleeve. I have been online looking for a different strut but nobody lists the od diameter of their strut. Can anyone tell me who makes a strut that is less then 2.125? I have checked Lakewood, Granatelli, QA1 and many others but cant get any specs.
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Dec 12, 2014
  • Dec 12, 2014
Have you gone to the Maximum Motorsports website?
W
Woodtick_02
  • Dec 12, 2014
Yes I did Mike but the problem Im having is that nobody lists what the OD is on the strut housing.
89oem
Mustang Master
Dec 18, 2013
1,456
542
144
Dec 12, 2014
  • Dec 12, 2014
Whose coilover do you have? They typically state in their documentation what strut to use.
W
Woodtick_02
  • Dec 13, 2014
Strange coil over sleeves.
W
Woodtick_02
  • Dec 13, 2014
After spending some time at the parts store going through different struts I found that 95 mustang struts will work with a small mod to them. They are a 1/2" longer but thats OK. Every thing went together great.
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
