Trunk Ideas Wanted
I have a 65 vert restomod project and was looking for ideas on how you all did your trunks for a more custom look, want an amp and sub in there but not anything totally outrageous, jut a nice clean look.
The outside of the car is red (or will be I should say) as is the engine bay, interior is all satin black. I was going to do the trunk body color too but I'm not 100% sure if that's what it should be or satin black to match the interior.
All ideas and suggestions are welcome
Cheers
I used the coupe trunk carpet kit, built a sub box that matches the angle of the sheet metal behind the rear seat and is vertical on the rear of the box. The carpet kit is just long enough to go up the back of the box and looks pretty clean. Mounted a 10" alpine sub in the box and a 5 channel kicker amp and done. Sorry for the crappy pics...IPhone.
Agreed, the entire interior is dynamated and then covered with heat/sound deadening wool like mat with silver material from mustangs plus (quiet ride solutions) the combo makes a huge difference in how quiet the car is inside and out.
I am over the hill (67). I have 360 watts running the passenger compartment speakers and 240 watts on the sub woofer. It's not a big thumper but puts out a great sound for cruising, especially with the top down. The panels are plywood with sheet metal for the curves. Side and rear panels are fiction fit and lift out. The amp/speaker panel is hinged to the floor so it folds down for access and storage space. You have to remove the cross tortion bars that hold the trunk lid up and replace them with gas lift cylinders. See attached pictures.
