trunk mount battery wiring questions
Raginstang
166
SANTA CRUZ CA
okay, I know I need to run my ground to the chassy, then to the engine block and then to the computer ground. my question is, where do you guys mount the long cable to the block at? and do you run it though the inside of the car or underneith? and I was thinking about attatching it to the heads but then I got all technical thinking and though that the headgaskets separate the heads from the block and wouldn't ground the block that well except through the bolts! he he, just wondering what you guys did. Im having hard starting hot. thanks.
p.s. i did hear that I nead to run the cables to my block from the battery. Im just wondering how you got it there and where you attached it.
I ran mine inside along the side of the car to the right of the seats (right of pass seat). I then attacked it to a bolt on the frame rail that i sanded down to get a clean connection.
