Trying to change rear pads...can't compress piston
sunil6784
620
Boston, MA
I'm trying to change my pads on my rear discs. But i cant seem to compress the brake piston, i use a C clamp, and it compresses a little, not much, but a little. When i release the clamp the piston pushes back out. Ive already tried opening the master cylinder a to release the pressure, but no luck. Any other suggestions, how far is the piston suppose to compress ?
Yup, you still need to screw the piston in to compress it.
They rent a tool at autozone that does this. Also, there is a disk brake caliper tool that looks like a cube you can use. You put it on the end of a rachet to screw it in.
There are two notches in the piston, the tool fits into these notches and you screw it in. It takes a while to screw it in so it may seem like it's not working. Just keep turning while applying some slight pressure to the piston. It will go in.
Make sure the notches are aligned to the 12 and 6 o'clock positon on the caliper when you are all done.
I tried the cube too, but then i saw that the piston didn't turn, but it went straight in and out. The cube seemed to slip out...i'll probably rent the kit from autozone tomorrow...thanks...
P.S...i dont know if this makes a big difference, but the notches are aligned to the 3 oclock and 9 oclock position...
For $40, Harbor Freight sells the same tool that Autozone has for loan.
I bought new calipers, and they came aligned at 3 and 9 o'clock. I'm going to assume this is correct (lincoln rear brakes).
THere the ones from the ford motorsport four wheel disc kit. I ended up just throwing on the old pads for now, its too nice of a day not to be driving the vert. I'll worry about it later....like when i cant stop. lol
Mavrick said:
I'm using the rear calipers from a Mark VII Mike, remember the brackets i bought off ya?
I guess the lincoln's are at 3 and 9, and the SN95's are at 6 and 12
haha of course i remember. I was directing that at the original poster :D
I bought a round attachment that goes on a ratchet from a small parts store near my house. It was $16 and fits perfectly on the piston. Fits much better than those crappy cube attachments. This tool is obviously made for this style piston.
