Trying to decide on a shift kit
  • Thread starter Thread starter 65fastbackresto
  • Start date Start date Aug 17, 2007
65fastbackresto
1,229
AR
Aug 17, 2007
  • Aug 17, 2007
I have a C-4 tranny, with a 2500 rpm stall. I want this car to bark 2nd gear but only when I want it too, its a street car and cant be doing that all the time.
Looks like B & M has several stages available in shift kits, any advice as to what would be appropriate for this application?
brianj5600
1,964
Middle TN
Aug 17, 2007
  • Aug 17, 2007
Use the Street/Strip version of a shift improver.
65fastbackresto
1,229
AR
Aug 17, 2007
  • Aug 17, 2007
Brian
Street strip it is. You were right on the linkage too, I have to carry the old tranny up to this guy Monday so he can take the linkage out of it and put it in the new one. I should have just taken it up there the first time....oops again.
You seem to be very knowledgeable about this stuff, what do you think of my 2500 rpm stall? Cam specs are 488 lift, 288 duration, and LSA of 108. Those numbers are close if not right on.
brianj5600
1,964
Middle TN
Aug 17, 2007
  • Aug 17, 2007
If you have a 289, I doubt an advertised 2500 will truly go 2500. They are usually about 200-300 rpm's lower when behind a 289 or 302. I think a 2800 or even 3000 will get you where you need to be. The 2500 would be ok, but I would be suprised if it goes 2500. If you want a true 2500, you have to get a different TC. Have you driven the car yet with that cam? If so, at what rpm does it come to life?
10secgoal
2,801
San Diego
Aug 17, 2007
  • Aug 17, 2007
I like trans-go myself. Still uses the vacuum modulator so it doesn't run around town trying to breaks parts all the time. It shifts hard only in the higher RPM's when you need it.
66bluepony
75
  • Aug 17, 2007
Shift Kit
Hands down its Trans-Go
brianj5600
1,964
Middle TN
Aug 17, 2007
  • Aug 17, 2007
I have heard a lot of good stuff about trans-go. B&M kit in my last trans used the modulator. My current VB has a home made shift kit.
65fastbackresto
1,229
AR
Aug 18, 2007
  • Aug 18, 2007
The car isn`t running yet
But its a mildly built 302, Edelbrock heads and intake, 10 to 1 compression. Thingking maybe 300 hp, at least hoping anyway. Btw, what is trans-go anyway?
rbohm
6,698
550
204
tucson,az
Aug 18, 2007
  • Aug 18, 2007
trans-go is another transmission company that also makes some really good trans parts and kits. B&M and trans-go both have excellent shift kits, and either one would be a good choice. the street/strip version is the best all around kit to use. as for the converter, 2500 rpm stall speed is just about right. brian makes an excellent recommendation for a car that is more strip than street, but an excellent recommendation none the less. for more street that strip, and for the cam you selected, you dont need much more than stock to see a big improvement though.
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
Engine on3 Conversion to draw through MAF?
  • sav22rem22
  • Oct 11, 2025
Fox 5.0 Mustang Tech Oct 11, 2025
sav22rem22
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
