Trying to hit 475hp to the rear wheels
Redsnake2
374
Philly, PA
i have the stock block, 42lbs injectors, stock cam, 2 T61 turbos( running 10lbs of boost), underdrive pulleys, 90mm Lightning MAF, custom SCT chip and a AODE w/2400 stall converter...
I'm thinking bout a set of thumper heads, and a holley systamax upper & lowr.
What do you guys think?
What is "custom" about your aode? There are a few things you'll want in one running over 500 hp. Also, get some bigger heads if you're going to be putting boost through the engine, might as well pick up a whole top end kit....but I would be concerned with your stock block or transmission breaking. To get 475 rwhp, you'll have to be making around 600 hp at the crank using an AODE....something to think about
I'm there with s-trim at about 17psi through a 4R70W and trickflow heads, stock cam and cobra intake (ported lower). Running methanol injection. Stock bottomend with 155,000 miles driven daily.
Went to SCT2400 MAF and 60lb injectors. Running two 255lph fuel pumps, one was not enough, stock rails.
With the turbos I'd kick it up to around 12-14psi and you should be there pretty easily.
Wes
