Tsb on front end
RICVA05
66
I read on another forum that there is now A TSB on the popping noise that most of us 05 owners have been experiencing it deals with the strut bearings the # I was given was (05-9-11).
This was over from MustangForums from ( Casper98GT )
TSB
05-9-11 FRONT SUSPENSION POPPING NOISE WHILE TURNING RIGHT OR LEFT - VEHICLES BUILT BEFORE 4/8/2005
Publication Date: April 27, 2005
FORD: 2005 Mustang
ISSUE:
Some 2005 Mustang vehicles built before 4/8/2005 may exhibit an intermittent popping noise from the front of the vehicle while turning left or right. The noise will typically occur during low speed maneuvers and may occur multiple times while turning.
ACTION:
On both sides of the vehicle, install a revised upper strut bearing assembly. If the vehicle was built before February, 2005 it may also be necessary to install a lower spring seat isolator if one is not already present. Refer to the following Service Procedure
hurdlinmasta said:
well, prob not, they would have to order it, cause it came out today.
So does that mean I should wait to take it in? I really dread taking my baby back to the dealer. Maybe I should just lower it and forget about the fix? Does lowering it permanently get rid of the problem? Anyone out there who has lowered their stang still experience the problem?
Taking mine in monday dealership said they will have to order parts could not order till they saw the car.The dealer also said he would give me the TSB # on the defrost problem I will give the # when I get it.
here is the one for the rear end and the shaker im having prob converting to pdf ill try later sorry it took so long here it is. i also have any other tsbs now on pdf axel chatter, gringing noise in 2&3rd
