invertmast said:
Ok,
I'm looking at getting a full tubular front suspension. I REALLY like the Maxmimum motorsports stuff, but i cant afford it. Soo i've come up with either QA1 or Granatelli motorsports. Does anyone have any experience with either of these companies? I've heard some companies make them out of materials that aren't the best for Daily street driving, i just forgot what material not to get.
Any suggestions are appreciated.
Thomas
If you're looking to do daily driving, then get one that is made of Chromoly steel. It is stronger than mild steel, and will hold up to the needs of daily driving without bending. I personally wouldn't buy the QA1 due to the fact that it is made in China, but then again, I'm going to be running their shocks and struts on my car, but that is only because I can't find a nice set of American made shocks and struts.
I have no personal experience with Granatelli. I've only heard people's reviews. Many people complain about Granatelli, so I don't know. Do a search, and see what you come up with.
If you're planning on running the stock springs, then you will need to either reuse your stock a-arms, or buy a set of a-arms with spring perches welded on to them. If convertering to coil overs, then you can run what ever kind of a-arm you pretty much want, just as long as it will fit the k-member. Be sure to also invest in a bump steer kit with any aftermaret k-member, as this is always recommended. You don't want to do a good job, and then end up having to tear back in there just to install a bump steer kit cause when you hit a bump, you have a hard time holding onto the steering wheel. If you converter to coil overs, get a set of caster cambet plates in a 4 bolt series.
I will be using the Maximum motorsport caster camber plates when I do a front end suspension swap and coil over conversion.
