Tuck...Un-Tuck
  • Thread starter Thread starter Fuzion
  • Start date Start date Nov 26, 2005
Fuzion
81
Virginia
Nov 26, 2005
  • Nov 26, 2005
I’m starting to piece together my 5 lug and cobra brake conversion on my 87 notch and seem to be stuck.
First, the rims I want to get only come in 17x9 with 5.85 back spacing and +24mm offset.
If I run 94-95 spindles with a 235/40/17 tire how far would the wheel stick out of the fender?
And if I go with stock length fox axles from North Race Cars
With the 17x9’s and a 275 tire would the wheel still be tucked in the fender? What my main concern is to eliminate the tuck un-tuck look of the wheels. I don’t like how the front tires seem to stick out of the wheel wells and the rears are tucked in. would I have this issue with this setup? Also would I have any major rubbing problems with what I have named above plus an h&r super sport springs drop?
old_blue
1,783
282
124
Nov 26, 2005
  • Nov 26, 2005
you may have to remove the quad shock for the rears to fit. some people have issues some don't. Is it lowered? that raises more issues with clearances as well. I think the front will be ok but I am not too sure. The rears will work, dependent on whether it is lowered or not.
Fuzion
81
Virginia
Nov 26, 2005
  • Nov 26, 2005
yea im going to be lowering the car with h&R super sport springs at the same time. do u think the front wheels will stick out further the backs?
Fuzion
81
Virginia
Nov 26, 2005
  • Nov 26, 2005
ttt
old_blue
1,783
282
124
Nov 26, 2005
  • Nov 26, 2005
hmmm, hard to say. Hopefully someone who knows more about backspacing can be more helpful. I still think you will be ok. I think if the back spacing were less (like around 4.5") then you would be hurting. You have a pic of the rims or the brand you are wanting to run? Someone might be running the same ones and could help you out more that way.
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
305-45-17 tires on Pony wheels (17")?
  • TTSaleen
  • Mar 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 25, 2026
TTSaleen
Wheel backspacing
  • Brad Hanks
  • Sep 25, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2025
Brad Hanks
G
Fox Tire Size for 16" Pony Wheels on 1984 LX Convertible
  • gw7
  • Jun 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2026
Qtrhrse23
O
Good all around perfornace-ish tires?
  • optionizerSS
  • Jan 25, 2026
2005 - 2014 S-197 Mustang -General/Talk- Jun 15, 2026
TPony
