For the fuel system I used my original 96 rails, had the brackets cut off and welded on so they would bolt up to a 99+ manifold.
Other stuff you will need: a 99+ intake manifold and tube, 99+ throttle body and cruise control cables, exhaust manifolds, a chip burned to turn off the IMRCs, modify the vacuum lines, lenghten some of engine wiring harness wires, a set of 99+ valve covers(you can run 96-98s but the fittment around the throttle body is very snug), a 99+ coolant crossover tube with an extra bung welded into to run the ECT and temp sender, and you may possibly need a new midpipe, my 96-98 bbk o/r H did not fit the 99+ exhaust manifolds so I got a VRS o/r X.
They all have the same valve diameters, 37mm int/30mm exh, but I do not know they are the same exact part number.
Al Papitto of Boss330 Racing built my shortblock, Lamotta performance assembled my longblock did the necessary welding work and later on tuned my car with the help of superchips.
