Tune Up Time
85MustGT
95
Occupied San Diego
My 98 seems to be ok when I drive, however bucks, when my daughter drove it (with me in the car) being it has just turned 50,000 I was thinking a tune-up might be in order.
I pulled one plug out, was an Autolight, and though it looked good I am not sure if have ever been changed, since I have only had the car alittle over a year. So I am thinking plugs, wires, pcv, fuel filter. Were Autolights or Motorcrafts original in my car?
Why are those plug wires so pricey? what do you recomend for wires and plugs?
motorcraft were original in your car. however autolite and motorcraft are the same. how are the plugs pricey? i got a set of Autolite 764's from wally world 2 for $1.85. the ford racing wires are really good. also you should change the coolant, tranny fluid and diff fluid. for coolant use green prestone and tap water, for the tranny use mobil 1 atf, for the diff use a quality synthetic 80w80 or 70w140 depending on what your diff says. the platnium autolites are maybe $2-3 a plug. i personally use the coppers because it gives me an excuse to more closely inspect my motor, plus the coppers are a more consistant spark producer.
:stupid:
In addition to what he said, change the fuel filter and pick up a bottle of complete fuel system cleaner and dump it in at the next tank fill up. Might also want to clean the IAC with some carb & choke cleaner.
no gasket needs to be replaced. the plug wires are expensive because they arent like a generic v8 spark plug wire. you have the coil packs and then the spark plugs have a deep boot. the coil packs have a different style connector that are unique to fords.
1tirefire said:
let your car warm up and then use a vacuum line to connect a hose from your plenum to the can of seafoam. It'll smoke for a while because you're cleaning the carbon out of the intake.
That sounds like a great idea. Not sure I fully understand what vacuum line is to be used. Can you exlain a little more in detail? Pics would be nice too.
