Tune?
There's no substitute for a good custom tune... but it gets complicated since the EEC4s can't be flashed like the new cars. I've used an AFM PMS in the past, and that was a suitable option. Many people upgrade to a standalone like FAST or Holley when they want to tune a Fox.
If you think it runs good then rock and roll.
If you want it to run better, find a reputable tuner and have them burn a custom chip for it. (not mail order)
Ya runs good, but not sure if getting a chip or tune will give me noticeable difference?
Was on a engine dyno. Added few parts afterward
Noticed it doesn't let me rev past 6200
The stock EEC doesn't let it rev past 6200 I heard, acts as a rev limiter ?
Just wondering how much power can the stock EEC handle till it has to be upgraded or if it even has to?
Mods
306 Refinished stock bottom end with girdle
Scat rods prob pistons afr 165 heads 1.6 rr cobra intake 65 mm tb 70mm mass 24lb inj 255 fp
Mac headers flow master exh no cats 373 gears
Was on engine Dyno when built with carb and stock 87 headers made 362 hp 358 tq
Went to the strip Friday was running 13.1 with no traction off the line. And had mt street slicks
Where should I go from here what would be my weakest link?
I'm thinking 410 gears ? And is the cobra intake restricting flow?
Most of these setups don't need more than 6200rpm.
You say you need to go past 6200rpm, yet have a cobra intake. My guess would be you really don't need to go past 6200.
Your mph along with your ET and 60ft will help determine if it's the car or you that is the problem.
Intakes aren't responsible for a missing 1-.5 seconds.
Maybe .2 at best with a 306 with another intake.
You don't need 4.10's or 4.33's.
3.73's are fine for most street cars.
Your 60ft time isn't that great for using ET streets.
106mph is a little low too.
I'd guess your issues have more to do with driving and practice and your setup. Rarely does anyone pull their best run on their one and only try.
If you can't hook up now with 3.73's, it only gets worse with 4.10s.
I agree. Work on your driving skills. Sounds like you are spinning through the 60ft. A deeper gear will onlly make it worse.
Couple of questions
What is the air pressure in the tires
how much of a burnout are you doing
what rpm are you launching at
