tuning and custom chip.
Daniel50
716
Discovery Bay, CA
Well i want to get a custom chip and some baseline runs done before my h/ci and i want a nitrous tune. the chip carriers two tunes and is 300 dollars all said and done. Believe its a predator. Chip re-tunable. one for all motor and one for nitrous. tuning is 125 an hour.
1. Should i intall my afpr or can than adjust my fuel pressure with the chip?
2. Do those prices sound right?
3. About how much power can you expect to gain from custom tuning with my mods?
4. How long is average?
5. And, with my setup would 24lb injectors hurt me? i want them for nitrous but want to know if they hurt me for daily driving and all motor runs?
1. No... do your tuning through pulse width, not fuel pressure.
2. The prices sound fine. I've seen it run a lot more.
3. It depends on how much power is waiting in your combination needing to be unleashed. (that's like asking how much power an exhaust pipe will give you. Answer: None... it frees up what's already there) If your current tune is poor then it will be a significant increase. If your current tune is good then you won't see as much of an effect.
4. Half an hour to strap it all up correctly. A few minutes for each pull. Then depending on how much tweaking across your power band requires will determine how much time will be spent doing it.
I (personally) would not bother with it. The stock AFPR is designed to provide the correct pressure for optimum spray pattern. You change the pressure, you change the spray pattern. It's much more efficient to adjust the air/fuel ratio by changing the amount of time the injector spends open, closed, and how far ahead of or behind the valve timing events it begins to fire or shutoff.
