Tuning Q's
  • Thread starter Thread starter stang22
  • Start date Start date Oct 19, 2004
stang22
1,318
Washington, D.C.
Oct 19, 2004
  • Oct 19, 2004
I dropped in my new motor a few weeks back and I would like to get some opinions on tuning. Here are the motor specs;
306
Thumper Heads
TFS1 cam with 1.7rr's and 24# injectors/76MM MAF
190LPH Fuel Pump
70MM TB and spacer
BBK LT's with O/R X
1. What plugs and what plug gap do you recommend.
2. What is the "desired" fuel pressure for this setup.
3. Anything else you recommend?
I plan on having it dyno tuned next month, but I wanted to try and get a head start. Thanks in advance.
Tim
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Oct 19, 2004
  • Oct 19, 2004
Stock plugs, stock gap and stock fuel pressure (to start). When you get a chance to dyno it, then you'll know if fuel pressure needs to be adjusted. Until then, your mods don't justify deviating from the stock 38-42lbs setting. Also, I see a shiny new GT-40 intake in that picture that's not listed in your mods. Anything else you might be forgetting to list?
stang22
1,318
Washington, D.C.
Oct 19, 2004
  • Oct 19, 2004
Here is a list I had typed up, forgot about it. I think that is it...
302 bored to 306
Thumper Heads, 1.7 RR’s, TFS 1 Cam (advanced 4 degrees)
J&E Pistons, Eagle Rods
Typhoon upper/lower ported
24# injectors with 76mm C&L MAF
MAC Fendewell CAI Kit
Proffesional Products SFI Balancer
MAC 70mm TB and EGR Spacer
190LPH Fuel Pump
Kirban Adjustable FRP
Performance Fuel Systems Fuel Pressure Gauge
BBK Jet Hot coated LT’s with off road Custom X and 40 series flows with dumps
MAC underdrive pullies
Engine Popping noise in the intake. Frustrated still.
  • esteban31065
  • Apr 6, 2025
Fox 5.0 Mustang Tech May 23, 2025
gkomo
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
Custom tune?
  • Nostang25
  • Jul 13, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 17, 2025
FastDriver
  • dan50
  • Jul 18, 2026
dan50
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
