I hope these questions aren't too elementary. Here is my setup and list of mods.
90' coupe, stock T-5, stock 8.8 w/373 motorsport gears, X2C boxer upper and lower arms, 15x8 Draglites with 26/11.50/15 ET Streets @ 9-11psi.
306 w/ Summitt flat tops, stock rods and crank, windage tray, Mac Long tubes and H-pipe into 2 chamber Flows, E-303 cam, stock fuel rails and stock 19lb injecors, cheap adj regulator @ 39psi, 76mm BBK T/B, C&L Truflo elbow, C&L 73mm MAF, K&N conical filter, Holey Systemax II Upper and lower intake, Manley one piece chrom moly pushrods, Protopline 180cc cast heads with with 58 cc chambers, stainless 2.02 int & 1.600 ex vlaves, Motorsport 1.6 RR, valve springs upto .510 lift. The car's best 1/8th to date is 7.94 @86 with 1.62 60' This weekend the car sucked ass. The best I could pull off was an 8.35 @ 82 with a 1.90 60' time. I don't understand it all. It's like it just has laid down on me. I just installed a Spec stage II clutch and UPR triple hook quadranat and firewall adjuster. I'd like some opinions on tuning it for the strip. I know what we threw at it and it didn't work at all. I'm not a seasoned veteran at tuning, but I thought that we had it dialed in pretty well. I guess I was wrong. Sorry for the long post, but I'm very frustrated right now and grasping at straws at this point. Any and all help is appreciated. I don't drive this car much on the street, but it is very streetable. It gets 18 MPG with this setup. I know there isn't much that can been done tuning wise with this stock computer, but surely you guys have some advice. Timing, plug brand and gap, and fuel pressure to my knowledge is about it. Right? What would you guys adjust all of these items at?
Once again, sorry for the long post. I really value everyone's opinion on here. I don't post much, but I read the forums a lot.
Thanks
Thanks
