For their 3/4 race cam and 750 double pumper? *Manly grunt*In this day and age, I don't know why anybody would voluntarily build a flat tappet motor.
@rbohm I'm not looking to start some sort of war here or anything. I simply disagree and feel that your advice is truly unfounded. Do you have a 2,000$ motor under the hood of your car that you can provide evidence of making 550hp? I just like the majority of the members here have a budget, and work inside that budget so I understand that there is money to be saved and everything doesn't have to be new. I for one have a host of used parts in my TTop car and has stretched my budget considerably. The advice I give here is from my real world experience and from past and current results. I just feel that your advice in this particular thread is unfounded and misleading, That's all.
find me a roller tappet cam that will work for a 200 or 250 inline ford six. also there are racing classes that dont allow roller lifters. and like i said, if you are building on a budget, a flat tapper cam is a good way to save money and still make good power. a roller cam and lifters runs about $500, where as a good flat tappet cam with lifters runs less than $200.
I'm not sure if you are accusing me of throwing money at my projects or just calling me plain stupid? Either way I'm ok with it. Still looking for examples, combos, time slips, etc. All of the information I post here is very open and honest. A spade is a spade and ask around I'm the first to admit to my mistakes, and like most other people I have made them and a lot of my advice stems from the things that I have learned along the years, good or bad. This last year in stepping up our racing program we had a tough and expensive learning curve. If you found a budget race combo that works would you mind sharing the specifics?i have built budget engines for years, including budget race engines. building an engine doesnt mean throwing tons of money at it and hoping for the best. its a matter of building smart. anyone can drop $5000 and make lots of power, not everyone can make the same power with about 1/2 the money.
Yea but you're dealing with lazy lobes and tedious break in procedures and even then a lot of guys will still end up botching a flat tappet cam install. Now lube companies are coming up with "break in oils" and "flat tappet oils" and its really just more hassle than it's worth, IMO. You save a couple hundred bucks, but you jump through more hoops and in the end an equivalent roller cam engine is going to do things better.
Class racing is another argument. That is what it is, I guess. Same goes for building old or obscure engines that roller cams aren't available for.
And if you're going to argue budget, consider that you can (usually) reuse roller lifters. So now you're at ~$100 difference in the two setups. That's a tank of gas and a trip to the movies. If that breaks anybody's engine budget, they shouldn't be building an engine.
