Alright, so I finally made the time get my car started after over a year of sitting
.. figuring out some wire was ripped out of the fuel pump relay under the seat..as it would still click without it. It had me stumped forever. Its always gotta be something stupid..(including myself sometimes ha) Anyway, onto the topic..the fuel pressure is set at 42 psi on the regulator, stock ecu and ignition, removed smog pump..The timing is at 8 degrees to be "safe". I havent driven the car yet..I put brand new o2 sensors, plugs and wires..using a blow-thru setup with the 80mm maf calibrated for 42lb injectors..the car starts right away but wants to die at idle..
my eyes start to burn within seconds..it'll do ok it seems if i hold the throttle a bit but dies when the gas is let off
. I hope that explaination is good enough for some help. I'm new to this site and a dummy when it comes to stuff like this. Haha.
