turbo kit for mustang?
  • Thread starter Thread starter 91notchback5.0
  • Start date Start date Oct 17, 2006
First Prev 2 of 2
millhouse
1,985
Simpsonville, SC
Oct 18, 2006
#21
  • Oct 18, 2006
  • #21
88_GT_5_oh said:
www.bgturbokits.com
or phone brian at B&G, he's also a member on turbomustangs.com
turbo > S/C
89Notch
1,669
MSU
Oct 18, 2006
#22
  • Oct 18, 2006
  • #22
You don't seem to be very knowledgeable on the subject so I would stick to a S/C... it will be a lot easier to manage.
9
91notchback5.0
#23
  • Oct 18, 2006
  • #23
Im not that knowledgeable on either all I ever had was nitrous cars, that is why i am asking these questions. Is there anyway to get more out of the V-1 without adding intercoolers and spending another $2000.
grey5.0beast
Cookies should never be DUNKED!!!
Aug 3, 2004
atl ga
Oct 18, 2006
#24
  • Oct 18, 2006
  • #24
pulleys are around 100-200 bucks and can give you around 3 more psi!
9
91notchback5.0
#25
  • Oct 18, 2006
  • #25
So if I bought the V-1 kit and just put on the pulleys I would get 3 more psi without changing anything else?.....fuel inj,etc.....
grey5.0beast
Aug 3, 2004
atl ga
Oct 18, 2006
#26
  • Oct 18, 2006
  • #26
well your just gonna get one pulley, a smaller diameter one for the s/c pulley which will make it spin faster herego more boost. You would be pushing the limit of the stock injectors with around 10 psi. on a stock motor, modded you would be looking at 24-30# injectors
89Notch
1,669
MSU
Oct 19, 2006
#27
  • Oct 19, 2006
  • #27
Boost is a measurement of restriction. Like grey said a smaller s/c pulley will make it spin faster shoving more air into the engine creating more restriction. It has nothing to do with the fuel injection. Now, if you change your intake to a better one, you might in turn reduce the amount of boost because you are reducing the restriction while still making more horsepower because you are putting more air into the motor. You should just read up on the subject, you should be able to find numerous articles using the search feature.
88_GT_5_oh
Sportin' a turbo 5.0 in Canadistan
Jul 4, 2004
WPG/MB/CA
Oct 19, 2006
#28
  • Oct 19, 2006
  • #28
a boost controller can be made from stuff available at home depot for like $10 and can give you 10+ psi more and if you get creative you can do it on the fly from the drivers seat
honestly if you know very little about either one. s/c may be better but a turbo system isn't all that much harder to manage. after all they are both only shoving more air into the engine, a turbo just does it with less strain on the motor
grey5.0beast
Aug 3, 2004
atl ga
Oct 19, 2006
#29
  • Oct 19, 2006
  • #29
i knoe this, if his motor is modded, he will need more injector to keep the A/F in check.
Gixxer750
789
Saint John NB, Canada
Oct 20, 2006
#30
  • Oct 20, 2006
  • #30
Lets not forget upgraded MAF once he swaps out to bigger injectors. Or a blow through for a turbo etc. I am in the process of putting together my Twin turbo kit, I have my 2 T3's now it is all the little things you don't think about when you get into it that add up really quick.
Fuel Pumps, MAF, Injectors, piping, fabrication, etc etc.
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Oct 20, 2006
#31
  • Oct 20, 2006
  • #31
Not neccessarilly...
You'll need to change your fuel pump and probably go with an adjustible fuel pressure regulator- about $200 worth for the 2 whether you add a pulley or not, and especially with a pulley
89Notch
1,669
MSU
Oct 20, 2006
#32
  • Oct 20, 2006
  • #32
He is mistaken... You don't need the fuel pump for more boost... you need the fuel pump to keep your motor from blowing up from the added boost
First Prev 2 of 2
393W Stroker with Boost - Need Spark Plug Recommendations
  • 387lx
  • Apr 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 30, 2026
HotFox
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
351w turbo build.... Turbo guys teach me things...
  • Kid wita 5oh
  • Oct 22, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 23, 2025
General karthief
M
Gt40p headers
  • Mike3
  • Oct 14, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 1, 2025
Blackhawkxx
Fox Help
  • 93fox85
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2026
