Turbo project DONE ,car is running and its nasty
Slow5.0
2,554
Portland, OR
Well first of all its not Stang its my brothers 96 Probe GT 5 speed
We worked together on this project for some time now and its all done ,car runs great and its nasty fast even on low boost wich is 12psi (thats what i have tunned so far) goal is run this car at 25psi on pump gas,but that will be in summer 07 because winter is here and i like to tune it on road (i don't belive much on dyno because almost everything is different on dyno)
On street tires in 3rd get at 30mph tires will go in smoke in no time,this turbo is big but there is no lag ,it spools up in no time and screams at 9000rpms
Here is list of mods
Engine:
Fully balanced and blueprinted engine 2.5L V6 DOHC
Bored .020 over KLDE Block
Ballanced stock crank
Wiseco Pistons/Pauter Rods Combo 8.7 CR
Ross Performance Piston Rings
Toga HP Oil Pump
Pro Topline Thrust Washers
Toga HP Main & Rod Bearings Combo
Ported/Polished KLDE Heads
ARP Head Bolts
Ported & Polished Intake Manifold
Throttle Body 67mm
Interprep 195lbs Valve Springs
Colt Performance Turbo Cams (INT: [email protected] lift - 274* advertised duration...EX: [email protected] lift - 240* advertised duration)
RR-Racing Racing Underdrive Pulley
Probe Addiction Header Primaries
QTP 3" Electric Cutout
255hp Walbro Fuel Pump
Modified fuel rails for Nissan 550cc's
Nissan SRDE20 & RB25DET 550cc's Injectors
PRD Disty Cap w/external coil & additional coil wire
MBX Ultimate Dual Feed Aeromotive FPR
Howe Racing Radiator
MSD 6A Ignition
MSD Coil Blaster 3
NGK ZFR7F11 spark plugs
Garrett GT35R (Turbine: .68mm w/84 trim, Housing .82AR.....Compressor 82mm w/56trim, Housing .70AR)
Flex-A-Lite Dual Slimline Fans 210R (pullers)
NCR Performance Turbo Pipes
NCR Intercooler Pipes (Powdercoated by EPC)
NCR 3" downpipe
NCR 3" Performance Turbo CatBack
NCR 3" TestPipe
NCR Silicone Couplers & Clamps for IC piping
Magnaflow Race Muffler
Precision 31.5x8x3 Intercooler
HKS SSQV Blow Off Valve
GP Sorensen IAT Sensor
Tial 38mm Wastegate .4 bar
Snow Performance Stage 2 Kit (WM)
DEI Turbo Insulation Kits
PRD Red Wrapped Spark Plug Wires
SS Braided Oil Lines (Feed -4an, drain -10an)
SS Braided Water Cooled Lines For Turbo -6an
RR-Racing Poly Engine Mount Inserts (Front & Rear)
Outlaw Engineering IM & TB Spacers
K&N 4" (inlet size) Air Filter
Tapped Oil Pan
Polished Valve Covers
Removed VRIS
Polished Alternator Housing
Modified CrossMember
Spectre Air Filter Breather
RR-Racing Short Throw Shifter w/ shift stabilizer bushings
Greddy (MBXmotorsports) Oil Cap
Drivetrain:
Goodridge Stainless Steel Clutch Line
MX3 GS Lighten Flywheel 15lbs
Red Tranny Saver
SouthBand DXD-F Clutch (rated up to 685hp)*
Suspension:
KYB Front Struts
Dropzone 1.75" Springs
Wheels/Tires:
Exel Speed 17x7 wheels
BFGoodrich g-Force T/A KDW NT Tires 225/45/17
Extra 2 SE 15" Wheels w/ BFGoodrich G-Force Drag Radials 225/50/15
Interior:
Autometer Phantom 5" Tach Gauge
Autometer Phantom Boost/Vacuum Gauge
Autometer Phantom Oil Pressure Gauge
Autometer Phantom Water Temperature Gauge
AutoVation Racing Pedals (Turbo Charged Design)
Carbon Fiber Switch for Launch Control
Carbon Fiber Switch for Switchable Tables
Ford Racing Steering Wheel Cover
Greddy Counter Shift Knob
Greddy Profec B Boost Spec II Controller
Green/Blue Reverse Glow Gauges
JVC CD Player KDS680
MegaSquirt (with lots of features)
Painted Red Interior Dash pieces
PLX M-300 Wideband
SPM black Triple A-Pillar Gauge Pod
Summit Racing Red Battery Relocation Kit
Here is short video before i tuned car (had safe tuneand WB was off on laptop, but was right at PLX Device wideband)
And the end you can see me got dizzy, car was running rich, couldnt get to myself for about 5 minutes lol
http://www.erietuners.com/videos/ThePunisher.wmv
Here is some pics after whole setup is done
Here is some pics of parts we use and some pics during build
Next things during/after winter will be:
- Build Tranny with Mazda 323 GTX internals
- Mickey Thompsons ET Street tires (2 of them) mounted on some superlight rims
- H&R 15mm wheell spacers
- either power slotted or cross drilled rotors
- either hawk or portefied brake pads
- brake braided lines (all around)
- Sensei SS hood
- Toxico Illumina Performance Shocks
- new front & rear bumper (due to having small cracks on it)
- rear seat delete (install plywood with black carpet on it)
- Red Bottle in the middle of that plywood covered with black carpet
- new carpet - change it from tan to black color
- Race Cage
- Probe Addiction Project Headlights
- DVD Screen 7"
- either keep stock tan leather seats or buy OBX or Spearco Leather Red Racing Seats
- Racing Harness
- Get last Phantom gauges (EGT, fuel pressure)
- FX Triangles for rear bumper (for car shows)
- FX Lip for front bumper (for car shows)
And finally new paint, keep same color (Laser Red - Candy) but paint roof in black color with either blue or brown pearls
93-97 Probe GT (Mazda MX6 LE) use aluminum KL06 engine ,block is two piece and there is no main caps ,whole lower block are main caps
from the factory engine is ballanced for over 7500rpms , now its a lot more than that lets say 10.000rpms plus
