Try to give you some back story. My 1st Fox had a Procharger, 3rd Fox had No2 (Track Car), 4th Fox I bought built with twin 70mm turbos.
This time around I'm doing my damnedest to be smart, simple, keep the quality up, fun high, drivability great. I really just want a fun daily drivable car. I don't want to open my original 68k mile motor up past the lower intake. So the plan is after all the suspension work, brake upgrades, wheels/tires are done I was going to install a Vortech V3 with zero intentions of going over 8psi on my stock motor.
Cobra Heads and Intakes keep popping up but I resist because it's not the time for that in the build plan and again I don't want to take the upper half of my stock motor apart.
Enter On3 and CXracing. Every day I see these kits running around for almost $1k less than my planned Vortech v3. I see a lot of guys running the kits with good success. Which got my thinking "Should I just go single turbo with 6-8psi of boost?"
What are your thoughts? Single Turbo or Vortech V3?
:::::I know reading this some of you are asking why I don't want to build and motor if I am going to use boost. I want to run low boost so I don't have to build the motor at this stage. I don't want the car winning races I want it to drive anywhere I want it to go and be fun. I'd love to throw a cam, AFR heads, intake, and 12psi but the block won't survive it. Now if I don't mess with what is working, run low boost, drive the car on the weekends and to work every now and then. It will last me long enough to save up for a nice engine build and make me smile between then:::::
