Turbocoupe/svo clutch in my 93 2.3L ?
POWER302
427
IL
I want a strong clucth to put in my 93 2.3L coupe. Im wanting to turbocharge the N/A motor soon and want a clutch that will handle it. will an svo or t-bird TC clutch work or whaty do I need to get?
The only difference between the TC/SVO clutch and the NA clutch is a slight difference in diameter.
To change to the larger clutch, you'll need to change the flywheel, clutch, and pressure plate.
Centerforce, Spec, and Ram all make aftermarket clutch parts for the 2.3T.
