turboing the 5.0
95at5.0
Fort Wayne IN
Does anyone have good reviews from ponydowns turbo kits? Im trying to figure out what the best turbo size for my 5.0 and the choices a 70mm with a 68ar or 70mm with a 81ar or a 76mm and unknown ar. all from ponydown.com
My motor has a unknown bottom end, x303 cam, gt40p heads 1.7 rockers, victor jr high rise intake, and 750cm holley with a 250shot of nos now. and is a 5spd car.
Hey bud. I can see that you didn't get much attention. Unfortunately, I could not find any credible information about ponydowns.
In any case, the turbos you're looking at sound like Master Power T70s since they commonly come with a .68 A/R and a .81 A/R. They could also be the older style garret T70s. These work fine in 5.0s and are capable of pushing 700-750 hp. I'd recommend the .81 A/R, which should spool quickly and can get you well over 130mph through the traps without the nitrous. The T70 is a great fit for the 5.0 because it make enough power to split the block, it's cheap, and should spool more quickly than the larger turbos.
Chris
