Well here are some pics that I have since my website is not done yet, enjoy.
Engine specs:
Its a Dart 8.2 based 331 w/ 9:1 compression. All forged internals (Scat 4340 Crank and H-beam Rods, Probe Dished Pistons), Clevite 77 bearings, Total seal classic race fittings, SFI Balancer, SFI Flex plate @ 28 ounces, Cometic Head gaskets, 7qrt Canton rear sump Drag pan, AFR 185's (ported), Trick Flow R upper and lower (ported), Custom grind Turbo cam. Injector's: Flow matched 72lb's.
Dart block w/ Cometic head gaskets:
Heads with rockers installed:
Side engine view:
Front engine view:
Upper and Lower Trick Flow R intake:
SFI Balancer and belt tensioner waiting to go on:
Built C-4 to handle all the ponies:
Won't miss any gears with this shifter
Custom PTC converter, just arrived today:
SFI Trans blanket, to save my feet:
Fuel system:
F.A.S.T. B2B system, to conrtol everything:
I have more pics, but this should do for now. Soon as I get the Engine and Tranny bolted into the car, then off to Turbo Technology for its custom SN94-95 Race kit. Will get pics of that during the build process for everyone.
Thanks for looking,
Will
Engine specs:
Side engine view:
Front engine view:
:Custom PTC converter, just arrived today:
Fuel system:
Thanks for looking,
Will
As far as times, I want to be able to drive it to the track on some new Micky Thompson Drag Radial's and run low 10's @ 135+ and then drive it home. Even with the C-4 I will have 3.27's out back which will place me around 2150 or so rpm @ around 65-70 mph cruising, still very streetable.
