Turn Siganls wont flash
Makdaddymac
323
orlando
Hey quick and easy fix im sure...
but my turn signals wont flash? they work like if i sit there and manual pull the lever up and down...all bulbs are working/replaced and brake lights work?
im sure it doesnt but would a 5speed swap maybe caused this...oh and im not sure if they were ever working cause i have done eveything to this car except drive..lol...:rolleyes: and ive only had it on one trip(illegal style) to go get my rear end put in......so yeah anyways is there a relay or something that goes out?? or what?
okay so near the pedals then?
um has anyone heard of the igniton switch mesing this up along with the hvac controls,a/c...
my a/c works randomly? its ice cold when it work but i was told it was the vacuum line under the hood which looks fine...:shrug:
could it be...i did have igntion switch problems where the car would die but i just tightend it up and it was good as new(well i crimped it tight)
Do your turn signals light up and stay on? If so, this is the blinker flasher. They were mounted various places depending on the year of your car. Check behind the glove box, behind the radio, and above the brake pedal (under dash). It's a small round cylinder about 1 inch around. Mine was light blue and near the brake pedal.
With the ignition switch, typically you'll have no turn signals at all and the blower for the HVAC also doesn't work. If this is the case, turn the ignition to the "key on engine off" (KOEO) position and gently rotate the key back and forth. If the blinkers and HVAC blower start working, your ignition switch is going bad.
Regardless of any vacuum issue, the blower motor will still work. Without vacuum to the HVAC system, I believe the air will only blow out the defroster vents.
