Turn signal Problems
  • Thread starter Thread starter jikelly
  • Start date Start date Jun 15, 2004
jikelly
20+ Year Stangneter
Jul 9, 2003
872
53
99
Lubbock Tx
Jun 15, 2004
  • Jun 15, 2004
Howdy,
The turn signals on a friend of mines 93 mustang just stopped working and I'm having trouble getting them going again. I tried fooling around with the contacts in the turn signal switch to see if that would fix the problem but that only made it worse. That sucks because a new switch is like 85 bucks.
Is there any chance that it could just be the flasher? I know there are two of them and if I can find them I am going to change them and see if that solves the problem.
Has anyone else had this problem and if so can you tell me how you fixed it. I guess I should also ask you where the flashers are located.
Thanks, wish me luck.
Boss 351
Here sthhhhhhhheeeve take a picthh of my man flowe
Jul 13, 2003
2,433
23
48
Canada
Jun 15, 2004
  • Jun 15, 2004
hmmm check the two grounds up front of the car that are screwed to the rad support frame. If that ground is faulty, the hazards will/might work but the flashers won't. I had a simular problem and after searching for a while I found it was the ground. Also check all the lights to make sure they all work and check the grounds.
sheff2720
182
Horsham, PA
Jun 15, 2004
  • Jun 15, 2004
i had the same problem about a month ago.. for me it turned out to be the turn signal relay was bad.. ive heard of them being all over for different years but i know in my car it was behind the glove box and to the left.. its a little blue solaniod.. just buy a new one and replace the old one.. easy 5 minute fix.. hope that helps
cjman15
Banned
Apr 15, 2004
1,009
Fairfield, PA
Jun 27, 2004
  • Jun 27, 2004
what year is your car?
cjman15
Banned
Apr 15, 2004
1,009
Fairfield, PA
Jun 27, 2004
  • Jun 27, 2004
nevermind, 92...
88stangmangt
2,332
Stafford,VA
Jun 27, 2004
  • Jun 27, 2004
your gonna waste more money and time messing around with it i know it is your turn signal switch. my lights went out with mine as well.
HISSIN50
34
129
Jun 27, 2004
  • Jun 27, 2004
while you were messing with the multi function switch, did you check for juice coming into the switch? if no juice, then there is atleast something else at fault (than the M.F. switch).
Fox Turn signal flasher keeps failing
  • keel
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
A
1966 Mustang coupe / Brake lights and left rear turn signal not working.
  • ArizonaRob1966
  • Nov 3, 2025
Classic Mustang Specific Tech Dec 24, 2025
Mcmahst
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
D
Turn signals work only with ignition on & Engine off.
  • DienstXIV
  • Jul 2, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 7, 2025
DienstXIV
D
SJB Parasitic Draw, Fuse 59&67
  • 2005 Mustang V6
  • Apr 30, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 29, 2026
boatillo
