partly right there; the hazard flasher is in the fuse box right under the steering column off to the right(round alumnimumcylinder). I had this problem where the hazard flashers only worked in my 1990 gt, the actual turn signal flasher isright behind the the a/c heater control panel right up from the radio.basically if you get throught the passenger side and look behind the radio panel by the tranny tunnel hump you'll see alight blue cylinder thats the turn signal flasher just pull it out, it's tuck on a l-shaped braket but yanks right out and disconnect the wires.
