turning signal (make me want to break things)
Kabuki_notch
670
394
113
Rochester, NY
well my front and back turning signals dont work so i did the obvious and bought new bulbs did that fix the problem? nope Im wondering If I got bad wires.. cause all my speakers wires have to be re run this weekend (thats another story all together) so my question is...how would one go about checking this to locate the source is there some sort of switch that may need to be replaced? im a tad annoyed thanks for any advice
-Rob
I recently had to replace my turn signal switch - try moving the switch up (or down for that matter) then wiggle it back and forth - if the flasher comes on at all, then you need a new switch - if not, check the wiring harness on the steering column, it may be that the power feed for the turn switch is loose.
I'm making the assumption that you've checked the fuses...right?
