TwEECer guys please help me out, I have tons a questions
Ok guys looks like I figure out ALMOST everything (I bean workin on TwEECer RT over 25 hrs in last 7 days)
Now there is a few things I don't know yet like
CALEDIT
-Under "Utilities" what I can do with
Copy Functions & Tabeles
Functions
Tabeles
CALCON
-Under "Plotting" what I can do over there with
Field list
Field for Graph
Display and all that stuff under Display
-Under "Setup"
What I have to put on MAF gauge max value
What I have to put on Speedometer correction multiplier
What under EVP signal transfer
What under DATAQ 4 chanel logger
What under Samples
What under Playback rate
AND can I or how I can get A/F ratio on Digital/Dashboard
P.S. when or if we figure out those I have a few more questions what something means but lets get this on top straight first
I use version 1.20 so I don't know about some of the new features of the version that you are using.
A/F ratio is displayed by the output of a wide band sensor. The wide band has nothing to do with the Tweecer but you can rig it up to show its data in a column of your datalog or as you talked about you can watch it real time in CalCon.
Samples are how many events you want to see with the playback feature in CalCon.
Playback rate is how fast or slow those samples are played back.
Later
Grady
CALEDIT
Functions
Tabeles
you can copy functions or tables from another calibration file using those. i have never used it, so i don't know if it works or not.
Slow5.0 said:
CALCON
Field list
Field for Graph
i don't use the plotting from calcon, what i have seen of it seems sort of worthless.
Slow5.0 said:
-Under "Setup"
What under Samples
-MAG max, EVP sig, DATAQ: i don't know about these, i haven't used them
-Speedo correction: if you have gears and your speedo is off, you can put in a correction factor here to show the correct speed in calcon.
- Samples: i dunno
- Playback: controls how fast calcon plays back a recorded log. i don't see the point in playing back a log, but you can do it if you want.
you need to hook up a wideband a/f sensor for that.
You can use the egr output to the pcm for your wide band cause the voltage outputs are about the same and it will show up in the Tweecer datalog along with the other sensor data.
I put mine on a toggle switch with the egr cause I run all of the emissions stuff.
Later
Grady
