  • 1994 - 1995 Specific Tech
tweecer install - please help asap!
  • Thread starter Thread starter BlackVert
  • Start date Start date Aug 9, 2004
BlackVert
5,589
9
98
Bethesda, MD
Aug 9, 2004
  • Aug 9, 2004
I have said it before and I'll say it again: I must be an idiot!
I am finally trying to install my TwEECer R/T, and I am running into difficulties. I can't get the GDMF computer out! In the pic below, I have removed the brass bolt in the upper right, and I have disconnected the 3 harnesses in front, but that is as far as I can get. I know I am supposed to disconnect the big harness at the bottom of the computer, and I have disconnected the 2 black clips, but I cannot get it off. I am guessing it is just "frozen" together from sitting like that for almost 10 years.
It dosen't help that it is impossible to get any leverage on it because of the angle ...
Did you have trouble getting it out? Any suggestions? Is it safe to spray it with WD-40?
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Aug 9, 2004
  • Aug 9, 2004
The big connector is held on by that bolt in the middle of it.
Once you get the EEC out and the TwEECer installed, you're going to have to remove the white harness from inside the kick panel -- the EEC won't fit back in there with it in place.
Dave
9
94DreamGT
593
Indiana
Aug 9, 2004
  • Aug 9, 2004
Kindof off topic here...but why did you spent the money on a TwEECer when you are still running stock heads and stock cam? That $500+ could of gone towards more productive go-fast goodies.
BlackVert
5,589
9
98
Bethesda, MD
Aug 9, 2004
  • Aug 9, 2004
ok, i got it out. i got it to read the eec, so i know it is working. but now when i try to start the car, the fan turns on and it just cranks. it even does that when i disconnect the tweecer.
i didn't F#$% my computer, did i?
1. very off topic there
2. they are ported stock heads.
3. i am planning on installing a cam in the future.
4. you can maximize mpg or hp with the tweecer.
5. i am planning on making more changes in the future, i can update the tuning myself.
6. i am a computer programmer, i am very interested in the workings of the eec.
BlackVert
5,589
9
98
Bethesda, MD
Aug 9, 2004
  • Aug 9, 2004
ok, it's working now. i hadn't screwed the bolt in far enough, so the 60 pin connector was not fully making contact with the computer ...
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Aug 9, 2004
  • Aug 9, 2004
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
A
Please!? I need some help with my 1964.5 alternator conversion
  • Alabear94
  • Dec 6, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 10, 2026
GOvert
G
O
1978 Mustang II Headliner Install
  • onusideburns
  • Nov 4, 2025
1974 - 1978 Mustang II Talk & Tech Mar 9, 2026
Enzio
