Tweecer Tuning A Mild Boost Setup- Help
  • Thread starter Thread starter BLOWN 5.0 FOX
  • Start date Start date Jul 18, 2005
BLOWN 5.0 FOX
213
NORTH SHORE MA
Jul 18, 2005
  • Jul 18, 2005
With my mods listed within my sig, I am attempting to perform a base tune on my own, before I bring it to the tuner to then fine tune. I have a Tweecer RT, which I am just now starting to get the hang of. I also have a PLX 300 WB to monitor the AF Ratio.
Is there anyone out there who has tuned a SC 5.0 with a Tweecer?
I have a 73mm C&L Meter... time to sell? or will it work fine as long as I find the correct MAF Transfer?
As of now the AF Ratio starts at 14.67 in CL and Leans out upon entering Open Loop. I have checked all vitals and there is no vac leaks etc, it just appears to be in need of a dialed base tune.
If anyone can help me out as to where to start tuning, I would apreciate it!
THANKS GUYS
BaXTeR3221
917
Orange County, NY
Jul 18, 2005
  • Jul 18, 2005
Basic things you need to address are injector slopes, breakpoint, and the Maf transfer. Maf transfer is going to be hard unless you have a flow sheet, which i dont think C&L's have. I would think that since you have the tweecer and are getting it tuned, it would be better to just ditch the FMU and pick up some 42's.(I have injectors and a matching Pro m for sale ) As a bonus, i can set you up with a base tune for the 42's and maf. Otherwise, thats a starting point. You should also check the tweecer forums, they'll be able to give you more help.
BlackFox5.0
3,514
Massachusetts
Jul 18, 2005
  • Jul 18, 2005
I think there is a pre-loaded maf calibration for the C&L 73mm with caledit, try loading it up and test it out.
Tomato
328
Calgary
Jul 19, 2005
  • Jul 19, 2005
You are gonna hav troubles with the FMU. I would get rid of it and get 30# or bigger injectors.
Don't need a maf transfer for the C&L.... just multiply the stock transfer by the ratio 19# injectors tio whatever the C&L is calibrated to (tube wise)...close enough, you can fine tune from there.
Small changes.... Time at high load to force open loop... set to 0 seconds... Leave the factory rev limit at 6500, but reset the fuel cuts to wherever your cam quits.... leave it with 50 rpm hysteresis between fuel on and off. Set base timing to 6 or 8degrees depending on boost, then add 8-9 degrees closed throttle spark, 8-10 degrees at part throttle spark. If she surges at idle, try reducing timing there.
Dunno if you wanna get into load scaling or not... the "purists" insist you gotta do this.... us old guys that never had tweecer, eec tuners, SCT etc..... know that the car should run perfectly well with matched maf/injectors... if you are having problems, chances are something else is wrong.
Mild boost on the supercharger will only REQUIRE changes to WOT spark and fuel....but an FMU sure can make a gawd awefull mess of your fuel curves...
BaXTeR3221
917
Orange County, NY
Jul 19, 2005
  • Jul 19, 2005
I agree, get rid of the FMU. As for the timing, i always thought were supposed to set the base to 10 and then use the tweecer to modify it from there?
BLOWN 5.0 FOX
213
NORTH SHORE MA
Jul 19, 2005
  • Jul 19, 2005
sorry but I need a little more opinions .....BUMP
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
G
2016 GT, Cold Air/Tune Trouble (overheating) . Advice/Help Please!
  • GLStang
  • Sep 6, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Sep 6, 2025
Tuning help! - HEGO 2 @ 64 volts!!!
  • VenomousISA
  • Feb 20, 2025
1996 - 2004 SN95 Mustang -General/Talk- Feb 26, 2025
VenomousISA
E
Nightmare after tune install!
  • EnemyofTyranny
  • Mar 29, 2025
2005 - 2014 S-197 Mustang -General/Talk- Apr 12, 2025
89ripper
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
