Twin Turbo Build Progress -pics-
SM0k3 said:
whos doing all the welding for you? thats my biggest problem....i've been thinking about getting a welder from harbor frieght and just practice.
my dad bought a tig welder last fall at the carisle swap meet, and its the best tool hes bought.....ive practiced so much on it, and its such a useful tool.....definately go for it, and practice a lot :D
green machine- the setup is coming along awesome man....big props to you for being the first to attempt this kinda setup on here......i cant wait to see it when its all finished man :D
^...we will see about that :D
Anyhow, i finally got em fully piped in and mounted. Its complete right out the tail-pipes. I also got the oil line from the sender fitting through a tee, out to the back of the car, i just need to do the return line now, finish my cold side outlets, and make up my cold inlets through the side vents( i ordered some zenon scoops to go over the area to give me some more room for filters
Anyhow, here are the turbos, You can see where i cut the wastegate flange and welded in some 2-1/2 tubes to go straight out to the tailpipes.
Here are the mounts i made to hang the turbos....nothing special, just holds em up there:
Pass side with oil feed hole
Drivers side
Here they are fully piped in
Here are the outlets where the turbos connect to the tailpipes
here is a pic of the 5/16 oil feed line
tommorow im gonna work on getting the cold side done now that i finally got all my flanges
i am very impressed with you. youve come a long way since i remember a couple years ago. dont listen to ol' boy up there talking about not making power. anything is better than stock. good luck, i hope everything goes flawlessly :nice:
