- Mar 25, 2004
- 23
- 0
- 0
ok guys im asking you what you guys think would be the better setup.....either a twin turbo setup or a single turbo set up....let me know what you guys think the best setup would be...thanks.
Dtowncats said:Why not go twin and get two diferent size turbos? The small one for low end torque and a bigger one for top end. I have a couple friends who have these types of set-ups in their cars( integra and talon) but man they fly!![]()
66Camaro454 said:
fivelitercoupe said:Why do you call bs. A good friend of mine has a twin turbo stealth with a 15g turbo up front and a 13g turbo on the back. It does work and also does allow for strong pull all the way through the rpm band.
Just imagine....supercharger gear whine up to about 3500rpm, then whistle of the turbo after that to about 8500rpm, then that blow off valve hissing durring the shifts....fivelitercoupe said:Why do you call bs. A good friend of mine has a twin turbo stealth with a 15g turbo up front and a 13g turbo on the back. It does work and also does allow for strong pull all the way through the rpm band.
89rdgt said:I would take the daily driven weekend racer of twin turbo. Just my 2 cents.
AXIStang said:Im just curious how they fit them both under the hood. I have friends with turbo'd Hondas and DSM turbos and their single 18G and T04e turbos barely fit between the engine block and radiator. we are doing another turbo install in a few weeks if twins will fit without major modification Id love to try it.
yeah the super/turbo setup was used on a lot of old school rally cars. I read something in MM&FF about that on the under pressure page...
sorry to get so far off topic btw...
