twisted wedge, or afr 165s?
  • Thread starter Thread starter steel1212
  • Start date Start date Jun 1, 2005
First Prev 2 of 2
steel1212
1,180
Frankfort, Ky
Jun 2, 2005
#21
  • Jun 2, 2005
  • #21
My lift is only .512 with 230 duration.
I think the twisted wedges from summit are like 1200$ and the cnc ported ones are like 1600ish.
The afr 165s are like 1300 from summit.
On the ford racing article the 165s out flowed the normal wedges but I wonder what about the ported ones?
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Jun 2, 2005
#22
  • Jun 2, 2005
  • #22
65fastback2+2 said:
Ive heard due to the valve placement in the TFS that the heads and valves wear considerbly faster than normal valve placement...
I've heard that too, but also that its just a case of getting the geometry spot-on. The same thing will happen to inline-valve heads if you side load the valves, but TFS/Holleys seem to be more sensitive(or just run more often with incorrect geometry).
My Crane 2031 is .513, 214* in/.529, 220* ex and combining that with the 1.90/1.60 valves of my Edelbrocks led to clearancing my pistons quite a bit.
steel1212
1,180
Frankfort, Ky
Jun 2, 2005
#23
  • Jun 2, 2005
  • #23
So do you think that 165s with the 1.90 intake and 1.60 exhaust valves will work with my stock pistons and that cam I listed a couple of posts up?
65ShelbyClone
4,675
38
119
Jun 2, 2005
#24
  • Jun 2, 2005
  • #24
Every engine combination is different, but I'm going to err on the side of caution and say no, your cam is too big for that piston/valve combo. My cam would have been fine if I used GT-40 heads like I originally planned or maybe with some DSS Prolite pistons(cleared for 2.02s) instead of Speed Pros, but I got a wild hair and bought Eddies instead. The sure way to find out is to clay your pistons when you get the heads.
steel1212
1,180
Frankfort, Ky
Jun 3, 2005
#25
  • Jun 3, 2005
  • #25
If its not going to work then there lies a problem. My engine is .060 over and at its limit. I don't want to open it back up to change the pistons when I really want to build a roller motor anyway. I was hopeing to get some good heads that I could use on this combo and then switch to the roller when I get around to building it
65ShelbyClone
4,675
38
119
Jun 3, 2005
#26
  • Jun 3, 2005
  • #26
At least you have a few options that I can see, though;
1. Call a custom Ford cam grinder like Buddy Rawls or FTI and see what they can do within the limitations of your parts. Probably will be in the $300 range just for the cam.
2. Get a shelf cam with alot less duration and/or lift. You can still make alot of power even with a stock 5.0 roller cam(.444" @ valve, in/ex). It wont have a lumpy idle, though.
3. Hold off and just build another engine, or.....
4. Buy a $30 Isky piston notching tool and use it with an old stock head and gasket to notch your pistons so you can use big valves and your cam. You'll have to be careful about the depth of the notches. Its like a valve, but with a serrated face so it can cut the notches. You can only use a stock head for this if you do not use TFSs(diff valve positions).
steel1212
1,180
Frankfort, Ky
Jun 3, 2005
#27
  • Jun 3, 2005
  • #27
I really don't want to change my cam out though. I'll probably end up either breaking down and getting new pistons and the heads I really want AFR 185s, or settling for 351 windsor type heads and build a whole new roller motor, mines not roller.
First Prev 2 of 2
SBF Head Flow Table - Work in Progress
  • Noobz347
  • Sep 29, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 30, 2025
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
A
Resolved Fuel pressure high at 52 new FPR same thing
  • afjLX
  • Dec 28, 2024
  • 3 4 5
4K
Fox 5.0 Mustang Tech Jan 11, 2025
AeroCoupe
