- Mar 31, 2005
- 427
- 0
- 17
just as the title suggests, what do people on here prefer on the 5.0? trick flow twisted wedge, or AFR 165, 185's etc... both power, quality, and ease of installation/tuning aspects... thanks
zenboy99 said:Trick Flow and AFR-165's flow about the same but the AFR has a smaller port volume.
walker95svt said:and yes, I do think heads can have a LOT to do with driveability, and I think that's what he meant by tuning. Are you saying a car with 8:1 compression and a gigantic cam and heads/intake with 302 cubes will tune up fine?
nmcgrawj said:I thought the twisted wedge was closer to the 185 than the 165, im not sure on flow numbers but in threads i have read, i just thought people put those two together.
I spend a ton of time on this site over there. There's a lot more Fox Mustangs on the road than 94-95's, so you'll inevitably receive more responses over there, but I don't think anyone here or there would try to steer you in the wrong direction. I think the guys over here are just as smart as the Fox 5.0 guys, they just have more numbers which equals more opinions on the subject. Now personally, I'm planning on selling off my GT40P heads at some point and getting a set of TW heads. I just like the idea that they've been around a lot longer, and have proven themselves time and time again with some incredible results.droptopford 5 0 said:...and i dont wanna hafta wander into that dreaded pre 94 5.0 section![]()
Bad idea...It's cheaper to get ONE set in pairs, than it is to buy ONE of each.YEAHLOH95 said:i would run one of each
94GTLaserRC said:Bad idea...It's cheaper to get ONE set in pairs, than it is to buy ONE of each.
Now, if cost is NOT an issue, then You could try it...If the car pulls harder turning left or right, then you know which cylinder head is making more power.
RC
94GTLaserRC said:Now, if cost is NOT an issue, then You could try it...If the car pulls harder turning left or right, then you know which cylinder head is making more power.
RC
Us old dudes think alikefinal5-0 said:That was the first thought I had when I saw that post as well RC![]()
I figured the car would only go in circles![]()
Grady
