two different vac gauges, two different readings
normally i run a vacuum gauge made by mallory ignition. it was brand new when i bought it. at idle it reads 20-22hg when not in gear. 18-20 when in gear. im going to put in a sc next week and im really excited about it so when my boost gauge came early, i decided to put it in and save myself 5 minutes worth of work later. anyways, its a brand new autometer sport-comp vac/boost gauge. at idle it reads 18-19 out of gear and in gear it reads 16-18. when the car is warm and in gear its usually 17hg. why the difference? one of them has to be wrong. i couldnt care less as long as its consistant. im only worried cause if the autometer is off on the vac, then will it be off for boost? it needs to be dead on for boost so i know what im running. how much "boost" can most people make with their lungs? i could blow in it to see what reading i get. what do you guys think?
And are you sure both gauges have a tight seal on the nipple. Back in the day, I had one gauge with a large nipple and it was a PITA to keep sealed up.
I also am not sure about the 'in gear' part - manifold vac is not dependant upon being in gear.
Said overly crudely: Manifold vac is inversely proportionate to how far the gas pedal is pushed.
Good luck.
both use a compression fitting to hold the very thin plastic line to the back of the gauge. they have a good seal. what i mean by in gear is, i have an aod. when it park, the idle is higher then when the trans is in drive and i have my foot on the brake. guess that doesnt matter, long story short, the autometer is reading lower by about 2-3hg
well i went back and pulled the gauge off. i cut the tip of the plastic hose off including the compression fitting. i put a new compression ring on the freshly cut hose, and put thread tape on everything. at idle the gauge reads 19hg, just under 20. is this about right?
Yep, 16-22" hg is good to go IMHO.
Also with the 'in gear' thing, if the reading is slightly lower with the brake applied, it might be the booster's affect on things.
Good luck.
Hiss--
There is an idle or rather "load" cahnge in the EEC When shifting out of park or neutral. It would account for the vac change as well. I've seen reference to it in the TwEECer forums. There is a scaler in the EEC just for that as well as an EEC controlled time delay to go along with it.
It's partly, to ensure that the motor doesn't die when shifting into gear.
Daggar said:
Hiss--
Ah so. Why thank you old wise one. :hail2: I try to learn something every day. Most of the time I forget it by the next day, but....... :D
BTW, why do you read about scalar values for autos? :p
I don't go looking for them. lol The TwEECer forums are not too different from these. I fell onto it a time or two while reading up something else.
I figured as much - I was just playing. :hail2: I know all sorts of stuff I dont want to know about just from reading forums. :D
I have lurked a bit myself on some of the TwEECer sites. If I stay, I will end up getting one. :nonono: (cant spend the funds on one, otherwise I would love it).
